I tried to replace the UPPER door gasket for our Whirlpool double oven mode GDB279PVS00. The Gasket has metal clips which are suppose to go into holes in the body of the oven. The clips does not match the holes pattern in the oven. I called Whirlpool and they confirmed that the part I received is correct. I called AppliancePartsPros to order another gasket, they informed me that the part's model number I received from Whirlpool is the correct one. I tried to install the gasket using different directions, the clips still does not match, is there anything I need to do. Suggestion are greatly appreciated.
