[quote=dillybob;279658]Help!!!
I followed this thread and combined it with the wiring instuctions which came with the switch. As a result, I have the switch working, but the other three now are not!
The switch I’m replacing is the first one in line from the power source.
The wires are as follows:
My original dual black: comes from the power source and has a splice in it that connects to the burner sensors on all the burners. It also has a dual connector that I have attached to P1. The other part of the dual connector goes to the next switch.
My original dual red: comes from the power source and also connects to the next witch in line. I have cut that dual and attached the power source to P2, and the other switches to 2.
My single orange is now connected to S2. it goes to the indicator light.
My purple and green are the inner/outer burner elements and are connected to 4 and 4a.
If I had to guess, (which I pretty much did already), I think I have to reconnect my dual red and attach it only to P2. Then do something different to connect the black spliced wire to the sensors.
Thanks for any help!!![/quote]
Dillybob,
What is your model and serial number ?
I believe you are correct ,
You will need to re attached the two red wires and install them on the P2 terminal on the new switch, and leave terminal 2 empty.
You lost me with the Black wires in your final statement.
It sounded like you had that connection proper in your first statement.
Did you see this post when you reviewed the forum posts
[LEFT][COLOR=#000000]Wire color or configuration is not “that” important, but location of the wire on the switch terminal or the component that the wire supplies is.[/COLOR][/LEFT]
[COLOR=#000000][LEFT][COLOR=#000000]First, install the jumper wire from P1 to S1 terminals on new switch[/COLOR]
[LEFT][COLOR=#000000]Red wire(single) on terminal 4 on old switch should be on terminal 2 on new switch and terminates at burner sensor circuit. [/COLOR][/LEFT]
[LEFT][COLOR=#000000]Red wire(dual) on terminal 5 on old switch should be on terminal P2 on new switch and will terminate at terminal block and jump over to the next infinite switch.(two directions).[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Black wire (single) on terminal 1 of old switch should be on S2 terminal on new switch and terminate at indicator light.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Black wire(dual) on terminal 2 on old switch should be on P1 terminal on new switch(beside jumper wire connection) and terminate at terminal block and jump to the next infinite switch(two directions).[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Brown wire terminal 3 on old switch should be on terminal 4 on new switch and terminate at outside burner element terminal on burner.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Yellow wire terminal 6 on old switch should be on terminal 4A on new switch and terminate at inside burner element terminal on burner.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Test burner operation, low and hi settings and re assemble the unit.[/COLOR][/LEFT]
[LEFT]I’ll get on a wiring diagram, and help you,as best I can as soon as I get a Model and serial number.[/LEFT]
[LEFT]
[/LEFT]
[LEFT][COLOR=#000000]Read more: Dual Infinite Switch Replacement [/COLOR][/LEFT]
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/120728-jenn-air-jed8430-dual-switch-replacement.html#ixzz10TuydgLH
http://forum.appliancepartspros.com [/COLOR]
[/LEFT]
