Discuss
Dual Infinite Switch Wiring
 in
Hi, I am trying to install a new switch, part number 12002125.The old switch does not match this one,it is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dual Infinite Switch Wiring
  #1 (permalink)
Old 11-05-2009, 12:43 PM
Junior Member
stewmcd is on a distinguished road
Default Dual Infinite Switch Wiring
Model Number: cce3401   Brand: Jenn-Air   Age: 5 - 10 years
Hi, I am trying to install a new switch, part number 12002125.The old switch does not match this one,it is identified on its side with TUDP 411.How does the old wiring layout relate to the new switch posts ?
Ads By Google
Related Models
Jenn-Air CCE3401B Surface Unit - Ele
Jenn-Air CCE3401Q Surface Unit - Ele
Jenn-Air CCE3401W Surface Unit - Ele
Jenn-Air CCE3450B Surface Unit - Ele
Jenn-Air CCE3450W Surface Unit - Ele
Jenn-Air CCE3451B Surface Unit - Ele
Jenn-Air CCE3451W Surface Unit - Ele
Jenn-Air CCE3530B Surface Unit - Ele
Jenn-Air CCE3530W Surface Unit - Ele
Jenn-Air CCE3531B Surface Unit - Ele
Jenn-Air CCE3531W Surface Unit - Ele
Jenn-Air CCE406 Surface Unit - Ele
Jenn-Air CCE406B Surface Unit - Ele
Jenn-Air CCE406L Surface Unit - Ele
Jenn-Air CCE407B Surface Unit - Ele
Jenn-Air CCE407B-C Surface Unit - Ele
Jenn-Air CCE407W Surface Unit - Ele
Jenn-Air CCE407W-C Surface Unit - Ele
Maytag CCE6200ACB Walloven - Std Mwave Ele
Maytag CCE6200ACE Walloven - Std Mwave Ele
Maytag CCE700 Walloven - S/c Mwave Ele
Maytag CCE701 Walloven - S/c Mwave Ele
Jenn-Air CCE9300BF Surface Unit - Ele
Jenn-Air CCE9300BG Surface Unit - Ele
Jenn-Air CCE9300GG Surface Unit - Ele
Jenn-Air CCE9300JD Surface Unit - Ele
Jenn-Air CCE9300PL Surface Unit - Ele
Jenn-Air CCE9300SL Surface Unit - Ele
Jenn-Air CCE9300SS Surface Unit - Ele
Jenn-Air CCE9300TG Surface Unit - Ele
Maytag CCF200  Freezer - Chest
Jenn-Air CCG2420B Surface Unit - Gas
Jenn-Air CCG2420W Surface Unit - Gas
Jenn-Air CCG2421A Surface Unit - Gas
Jenn-Air CCG2421B Surface Unit - Gas
Jenn-Air CCG2421W Surface Unit - Gas
Jenn-Air CCG2422B Surface Unit - Gas
Jenn-Air CCG2422W Surface Unit - Gas
Jenn-Air CCG2423B Surface Unit - Gas
Jenn-Air CCG2423Q Surface Unit - Gas
Jenn-Air CCG2423S Surface Unit - Gas
Jenn-Air CCG2423W Surface Unit - Gas
Jenn-Air CCG2520B Surface Unit - Gas
Jenn-Air CCG2520W Surface Unit - Gas
Jenn-Air CCG2521A Surface Unit - Gas
Jenn-Air CCG2521B Surface Unit - Gas
Jenn-Air CCG2521W Surface Unit - Gas
Jenn-Air CCG2522B Surface Unit - Gas
Jenn-Air CCG2522W Surface Unit - Gas
Jenn-Air CCG2523B Surface Unit - Gas
Jenn-Air CCG2523S Surface Unit - Gas
Jenn-Air CCG2523W Surface Unit - Gas
Jenn-Air CCG406 Surface Unit - Gas
Jenn-Air CCG406B Surface Unit - Gas
Jenn-Air CCG406L Surface Unit - Gas
Jenn-Air CCG406S Surface Unit - Gas
Jenn-Air CCG456 Surface Unit - Gas
Jenn-Air CCG456B Surface Unit - Gas
Jenn-Air CCG456BC Surface Unit - Gas
Jenn-Air CCG456W Surface Unit - Gas
Jenn-Air CCG457B Surface Unit - Gas
Jenn-Air CCG457W Surface Unit - Gas
Jenn-Air CCG556B Surface Unit - Gas
Jenn-Air CCG556W Surface Unit - Gas
Jenn-Air CCGP2420P Surface Unit - Gas
Jenn-Air CCGP2420PF Surface Unit - Gas
Jenn-Air CCGP2420PG Surface Unit - Gas
Jenn-Air CCGP2420PR Surface Unit - Gas
Jenn-Air CCGP2420PU Surface Unit - Gas
Jenn-Air CCGP2720P Surface Unit - Gas
Jenn-Air CCGP2720PG Surface Unit - Gas
Jenn-Air CCGP2720PK Surface Unit - Gas
Jenn-Air CCGP2720PR Surface Unit - Gas
Jenn-Air CCGP2720PU Surface Unit - Gas
Jenn-Air CCGP2820P Surface Unit - Gas
Jenn-Air CCGP2820PR Surface Unit - Gas
Jenn-Air CCGP2820PU Surface Unit - Gas
Jenn-Air CCGX2420B Surface Unit - Gas
Jenn-Air CCGX2420W Surface Unit - Gas
Jenn-Air CCGX2620B Surface Unit - Gas
Jenn-Air CCGX2620W Surface Unit - Gas
Whirlpool CCH12AEK
Whirlpool CCH12ASK
Whirlpool CCH12WEK
Whirlpool CCH12WSK
Whirlpool CCH470AE2
Whirlpool CCH470WE2
Whirlpool CCH9AEK
Whirlpool CCH9ASK
Whirlpool CCH9WEK
Whirlpool CCH9WSK
Whirlpool CCK401TS
Amana CCMA2000 Commercial Microwaves
Amana CCMA2000BK Commercial Microwaves
Amana CCMA2230 Commercial Microwaves
Jenn-Air CCP457B Surface Unit - Gas
Jenn-Air CCP457W Surface Unit - Gas
Jenn-Air CCP556B Surface Unit - Gas
Jenn-Air CCP556W Surface Unit - Gas
Jenn-Air CCR466 Surface Unit - Ele
Jenn-Air CCR466B Surface Unit - Ele
Jenn-Air CCR467B Surface Unit - Ele
Jenn-Air CCR467B-C Surface Unit - Ele
Jenn-Air CCR467W Surface Unit - Ele
Jenn-Air CCR467W-C Surface Unit - Ele
Jenn-Air CCR567B Surface Unit - Ele
Jenn-Air CCR567B-C Surface Unit - Ele
Jenn-Air CCR567W Surface Unit - Ele
Jenn-Air CCR567W-C Surface Unit - Ele
Jenn-Air CCS446 Surface Unit - Ele
Jenn-Air CCS446-C Surface Unit - Ele
Jenn-Air CCS446W Surface Unit - Ele
Jenn-Air CCS446W-C Surface Unit - Ele
Jenn-Air CCS447B Surface Unit - Ele
Jenn-Air CCS447B-C Surface Unit - Ele
Jenn-Air CCS447W Surface Unit - Ele
Jenn-Air CCS447W-C Surface Unit - Ele
Whirlpool CCS50AE
Whirlpool CCS50AE1
Whirlpool CCS51AE
  #2 (permalink)
Old 12-07-2009, 07:57 PM
Junior Member
tomjust is on a distinguished road
Default TUDP switch to 12002125
Quote:
I have the exact same situation. Looking for info on which wires go to where....
  #3 (permalink)
Old 04-02-2010, 05:58 PM
Junior Member
joulupukki is on a distinguished road
Default Wiring for 12002125
I connected the 12002125 as follows:
Range Type: JENN-AIR SCE30600W
L1 Phase (black wire coming from front left switch) to P1
Jumper wire from P1 to S1
L2 Phase (red wire) to P2
Black wire going to heater to 2
Orange wire (indicator light) to S2
Rose wire to 4
Purple wire to 4a
So far it seems to work
The swich however does not fit mechanically. I needed to shim the switch to prevent infringement
with the holder of the indicator light.
  #4 (permalink)
Old 01-01-2012, 12:42 PM
Junior Member
mikecarter is on a distinguished road
Default
I have a Jenn Air CCE3531W and just replaced the dual infinite burner switch. The replacement part# is 12002125. The directions that came with the replacement were poor at best. After about 9 attempts I finally figured out the wiring. It is as follows:
Jumper wire supplied with new switch hooks to P1 and S1.
Double red wires must be separated and a new spade clip put on the one that comes from the inner RR burner. Put the red wire from LF switch on P2, and the red wire with the new spade clip on 2.
Gray wire from the burner on indicator light goes on S2.
Purple wire from outer part of burner goes to 4A.
Blue wire from outer part of burner goes to 4.
When completed, you will have to put a small piece of folded paper in the knob to shim it up to keep it from rubbing on the glass surface.
  #5 (permalink)
Old 08-18-2012, 02:20 PM
Junior Member
djwocky is on a distinguished road
Default
I have a 3401 Jenn Air, these directions are spot on but note that even though this unit has the "compound" wiring, no need to split the Red wires because they already are split, both going to separate dual terminals on the old switches N connector.
Use the Jumper from P1 to S1
Tan to 4
Yellow to 4a
Orange to S2
Black to P1
As for the wires that went to the two N terminals on the old switch:
Main Red (L2) goes to P2 (this is the hot wire that also goes to 2nd switch
Red from the burner goes to 2
  #6 (permalink)
Old 09-01-2012, 11:11 AM
Junior Member
rockshadow is on a distinguished road
Default
I have a Jennair Model #JED8430ADB, any help out there for the correct wiring of the infinite switch? I have a red wire that is a compound connection coming from the back left burner and coming from the right rear switch. Also, black wire is a compound connection with the same back left burner/right rear switch connection.
  #7 (permalink)
Old 11-12-2012, 09:36 PM
Junior Member
RomanSz is on a distinguished road
Default Wiring help...the schematics look very different
Thank you djwocky..I am not sure if you are still monitoring this post. I looked at the schematic (switch) on the factory diagram of my CVE3401b and its very different then the one included with replacement switch 16023363. I feel uneasy to connect as stated w/o understanding the functionality and differences of those 2.
I am attaching both schematics and any help will be much appreciated (my stove is on the floor and the wife is not very happy :-).
Tan to 4
Yellow to 4a
Orange to S2
Black to P1
  #8 (permalink)
Old 01-08-2013, 06:14 AM
Junior Member
fyao is on a distinguished road
Default
I am new to the thread and do not know if anyone is continuing monitor it. I also have a CVE3401B but am trying to replace the switch for the Right Rear small single burner. I followed the instructions and separated the red wire. However, we can only have the indicator on. The burner remains cold. I tried to see the switch on RomanSz's schematics but it was cropped out. Could I get the schematics of the Right Rear burner? Or someone who has solved the problem could help me out? Thanks in advance.
  #9 (permalink)
Old 01-13-2013, 02:07 PM
Junior Member
jim@inspectech.net is on a distinguished road
Default Model CCE3400W
I too am changing out the switch, I see some slight differences. I have the following: Red (2 wires single connector), Black (2 wires single connector), Orange, Purple, and Blue. If you can tell me which numbers on the new switch i should connect to with the new switch P/N12002125. Stove model CCE3400W. Thanks.
  #10 (permalink)
Old 01-13-2013, 05:28 PM
Junior Member
Default Additional information on the original wiring
Quote:
My original wiring shows: One single black wire connected to H1 and one single black wire connected to H2 (the two look like equivalent of Yellow wires on the diagram). Then one black wire from the indicator connected to P. Double black wire connected to L1 and double red wire connected to L2.
I separated the double black wire and double red wire and connected all wires as shown in the instructions: H1 to 4, H2 to 4a, P to S2, L1 to P1, and separate L2 double red and attach the one from the other switch to P2 and the one from the element to 2. Insert the jumper from P1 to S1. The result is that the indicator works but the burner does not.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 5 11-24-2009 02:14 PM
Wiring for dual infinite switch captain stan Oven Repair (including Ranges and Cooktops) 0 05-16-2009 02:37 PM
Dual Infinite Switch Replacement david.freeland@sacorp.com Oven Repair (including Ranges and Cooktops) 1 09-24-2008 03:30 PM
Replacing Dual Infinite Switch on Range juchunk Oven Repair (including Ranges and Cooktops) 0 05-02-2008 07:51 AM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 01:04 PM
