clintvic
#1 Posted : Saturday, June 5, 2010 7:38:55 PM(UTC)
clintvic
I need to replace the relay board for the oven but can't find any links for a part number or links for ordering descriptions.
I did get a part number from Sears 22-364-WB27x425 but that number went nowhere. Just like the Sears Parts site.:( :confused:
#2 Posted : Sunday, June 6, 2010 3:43:15 AM(UTC)
Could this be it?
Part number: AP2025475
Click on the picture to get more info.
clintvic
#3 Posted : Monday, June 7, 2010 8:29:10 AM(UTC)
clintvic
This board is very close. There are 3 small cans (for lack of the proper word) and i think resistors to the left of the transformer (see empty holes left of transformer on picture. I can attach a picture if only I knew how.
#4 Posted : Monday, June 7, 2010 11:42:01 AM(UTC)
The part I showed was what came up when I used WB27x425 to search on the AppliancePartsPros parts site.
If you got the number directly off your old board then odds are it is the correct one.
I cannot comment why it does not have the resistors and unfortunately getting info from GE is harder than Sears. Could be the part has been updated.
By the way the "cans" are the relays.
clintvic
#5 Posted : Monday, June 7, 2010 4:19:06 PM(UTC)
clintvic
The part # from my owners manual is 337633. I don't know if that would be of any help.
The part # that I gave you earlier was from the Sears service dept computer.
clintvic attached the following image(s):
#6 Posted : Tuesday, June 8, 2010 1:02:34 AM(UTC)
When I use that number I also come up with the same board AP2025475.
Looking at the capacitors and resistors I would guess they are spark arrestors for the relays. May well be they have been removed as they were causing more problems than solving.
AP2025475 is $165.47 made by GE
But what also comes up is AP3104398 at $98.33 made by Whirlpool.
I would call or email AppliancePartsPros to see if they can confirm that there is no difference in the boards and if there is no difference I would get the cheaper one.
clintvic
#7 Posted : Tuesday, June 8, 2010 7:59:20 PM(UTC)
clintvic
Summary of this post:
Kenmore # 33733 replaced by WB27x425, GE # AP2025475
Whirlpool #AP3104398, WB27x519 is different from GE above.
I researched the pictures for the Whirlpool board and it only has 3 wire terminals on the right side of the board - needs 5. It also only has 4 wire terminals on the bottom of the board and it needs 6.
After checking all links and pictures, I will need to get the GE board AP2025475 @ $165.47 from Appliance Parts Pros. They are the least expensive and there shipping to Hawaii is very reasonable.
Thank you for all your help in finding numbers and pictures. I hope that this post will be of help to someone in the future.
Aloha clintvic :)
LG Oven Relay Board Keeps Burning (Oven Repair (including Ranges and Cooktops))
by greenman1985 8/15/2017 4:07:54 PM(UTC)
Need detail directions for replacing main relay board part # 92029 (Oven Repair (including Ranges and Cooktops))
by yzdeaner 5/23/2017 11:45:15 AM(UTC)
how do I replace relay board on amana oven (Oven Repair (including Ranges and Cooktops))
Belarus ghappe 11/4/2013 11:30:31 AM(UTC)
Relay board (Oven Repair (including Ranges and Cooktops))
by giuseppe105 5/28/2012 6:00:11 AM(UTC)
Dacor Double Wall Oven-replace lower oven relay board (Oven Repair (including Ranges and Cooktops))
by CatsR 12/27/2010 10:56:52 AM(UTC)
Thermador relay board is bad (Oven Repair (including Ranges and Cooktops))
by John McAuliffe 10/2/2010 7:56:51 PM(UTC)
Installing AP4009507 lower relay board in a Jenn Air ww30430w (Oven Repair (including Ranges and Cooktops))
by TimMiller 1/17/2010 10:03:26 AM(UTC)
Jenn Air F5 error code - "Clock" or Power relay board? (Oven Repair (including Ranges and Cooktops))
by chanpaul 11/22/2009 1:13:48 PM(UTC)
Jenn-Air Oven Lower Relay Board (Oven Repair (including Ranges and Cooktops))
by Terry Burgin 11/5/2009 2:09:04 PM(UTC)
Replace Relay Board (Oven Repair (including Ranges and Cooktops))
by JackieC 2/2/2009 8:33:41 AM(UTC)
Control Panel, Relay Board or Clock Timer? (Oven Repair (including Ranges and Cooktops))
by Guffey 12/9/2008 7:13:49 AM(UTC)
relay board for (Refrigerator & Freezer Repair)
by ccrumrine 11/20/2008 5:04:07 PM(UTC)
Relay board problem??? (Oven Repair (including Ranges and Cooktops))
by Daryl66 4/13/2008 7:28:22 PM(UTC)
How to replace relay board? (Oven Repair (including Ranges and Cooktops))
by Marc Lombardini 11/27/2007 10:17:18 AM(UTC)
