Terry Burgin
#1 Posted : Thursday, November 5, 2009 2:09:04 PM(UTC)
Terry Burgin
:) I purchased a replacement relay board for my Jenn-Air Oven Model # WW27430P. I was sent the following Part number 12001914, Description CNTRL-ELEC, Order Number 873419 from Location 5W4503.
On the accompanying instruction sheet it states that this part is used on models with serials ending with (ZU, ZW, ZY, ZZ). My serial # is 10377090SS.
Is this indeed the correct part and will it work properly with the Jenn-Air Model WW27340P? If this is incorrect, please tell me how to rectify the problem and how to recieve the proper replacement part post haste.
Please advise.
Thank you.
Terry Burgin
#2 Posted : Thursday, November 5, 2009 4:31:28 PM(UTC)
Terry,
If you are looking for the lower oven relay board then the relay board with the part number 12001914 you received, is the correct part.
