Eleazar
#1 Posted : 15 years ago
Eleazar
compressor sound like it work and so is the evaporator fan and the condenser fan but not cooling or freezing at all, I am thinking that is in defrost all the time, but the compressor is runing, does the compressor runs when on defrost? any sugestions?
#2 Posted : 15 years ago
Are you sure the compressor is running. Feal the smaller tubing as far away as possible from the compressor. Should be hot. Also, pull out the freezer back panel and check for some frost. If there is some, either your system is low on refrigerant, or your compressor is bad.
Eleazar
#3 Posted : 15 years ago
Eleazar
Mr. richappy thank you for your quick respond, and yes the compressor runs but I don't feal the bibration as it should be,the small tubing is not hot and no ice on the evaporator coil so you think is the compressor?
thank you for your help
#4 Posted : 15 years ago
Pull the cover off the side of the compressor and remove the start device. If it rattles, it's bad. Order a new one here, AP4079373
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 3 years ago
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 3 years ago
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 3 years ago
please help kitchen aid fridge noise (Refrigerator & Freezer Repair)
by marcelmcesar 4 years ago
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
by swingbyte 4 years ago
Fisher & Paykel DEIX2 Dryer Keeps tripping t-stat Please Help (Dryer Repair)
by hotlicksexhaust 5 years ago
Silence is definitely not Golden (LG) ... Please help (Microwave Repair)
by benh1234 6 years ago
Please Help - Whirlpool WFG524SLAS (Oven Repair (including Ranges and Cooktops))
by yozzomp 6 years ago
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 7 years ago
Mystery part loose in box - please help identify! (Refrigerator & Freezer Repair)
by xkandakex 7 years ago
PLEASE HELP! Quiet Partner III Cancel, Rinse Only Lights Blinking (Dishwasher Repair)
by zed40 8 years ago
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 8 years ago
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 8 years ago
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 9 years ago
Please help with my GE replacement motor wiring (Dryer Repair)
by Mjutton 9 years ago
