Hello all, I've been having this problem for quite some time and it's literally driving me crazy. My oven burners and broil work with no problem but when I use Bake, it will ignite (sometimes first try but not all the time) then when it hits the set temp, it will fail to re-ignite. I hear 3 clicks and the sound and smell of gas but it will not re-ignite, sometimes if I'm lucky, it will. I also see a spark on the igniter as well. First I replaced the Spark Control module and this did not fix the issue. I then replaced the bake igniter, still no luck. Could it be that I have a bad gas valve even though I hear and smell gas when it tries to ignite? Another thing that I've done was drill additional holes on the bake burner which also didn't work. I'm stumped... please help! Edited by user Wednesday, December 5, 2018 1:29:35 PM(UTC)
| Reason: Not specified
