Dryed a load of clothes fine then put the 2nd load and dryer would not start,The timer runs the on push button clicks and thats all it will do! Any ideas?
A model number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
Sorry! This is the model # Keys850LQ2 Found on the inside of the dryer door!
Remove the rear panel and check the thermal fuse (#6 on the diagram) for continuity. If the fuse is open, replace the thermal cut-off and high limit thermostat (#8 & #15) and clean the vent line all the way to the outlet. - The thermal fuse Part number: AP3133489
Thanks thats exactly what was wrong! Got it fixed!!
You are welcome. We are glad you were able to fix it.
