help dryer wont run i push the start button it will start then i let off it shuts off does the inside of the dryer basket supposed to turn real easy i can barely move it
Originally Posted by: indybassin help dryer wont run i push the start button it will start then i let off it shuts off does the inside of the dryer basket supposed to turn real easy i can barely move it Indy, You're on the right track, Yes, you should be able to rotate the drum, it's not easy, but should not be as hard as you make it sound. You most likely have a bad motor switch circuit or loose / broken wire at the motor connection. Part number: AP3094245
There is a slight possibility, of a bad timer contact, but it's pretty remote. :) :) :)
