indybassin
#1 Posted : Monday, February 21, 2011 1:17:15 PM(UTC)
indybassin
help dryer wont run i push the start button it will start then i let off it shuts off does the inside of the dryer basket supposed to turn real easy i can barely move it
Joe / APP Team
#2 Posted : Tuesday, February 22, 2011 12:11:04 PM(UTC)
Joe / APP Team
Indy,
You're on the right track,
Yes, you should be able to rotate the drum, it's not easy, but should not be as hard as you make it sound.
You most likely have a bad motor switch circuit or loose / broken wire at the motor connection.
Part number: AP3094245
There is a slight possibility, of a bad timer contact, but it's pretty remote.
dryer wont run (Dryer Repair)
by gjack45pac 11/28/2015 9:40:28 AM(UTC)
by patriots 4/26/2015 10:21:36 AM(UTC)
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
dryer wont run control panel lights up (Dryer Repair)
by bobbijo 8/11/2013 2:13:57 PM(UTC)
Dryer wont run (Dryer Repair)
by wtester 12/3/2012 3:20:38 AM(UTC)
by jlp10 5/31/2011 4:34:08 PM(UTC)
Maytag electric dryer wont run (Dryer Repair)
by crotonoil 12/9/2010 1:40:55 PM(UTC)
by latj 5/26/2010 5:11:49 AM(UTC)
by jgiff@att.net 1/25/2010 6:33:35 AM(UTC)
Maytag dryer wont run (Dryer Repair)
by Dennisb 1/5/2010 2:14:39 PM(UTC)
dryer wont run after making squeaky noise (Dryer Repair)
by pattie 9/18/2009 10:59:40 PM(UTC)
by nairobi 9/16/2009 2:02:01 PM(UTC)
dryer wont run at all (Dryer Repair)
by neighbor 9/16/2009 7:04:39 AM(UTC)
by danielle 10/22/2008 5:55:37 PM(UTC)
