Dennisb
#1 Posted : Tuesday, January 5, 2010 2:14:39 PM(UTC)
Dennisb
Rollers were rumbling,so I ordered new ones, just before they got here the dryer wont run at all. door switch checks ok, tried turning off the breakers to try a reset, The timer display and lights work on the controls. All I get is a beep and I can hear a click when I press the start button.
Any ideas would be appreciated
Dennis
#2 Posted : Wednesday, January 6, 2010 3:40:59 AM(UTC)
Replacement parts for med9600sq0 models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208563816.pdf
First things I would check is the thermal fuse on the blower and the belt switch both are in the motor circuit.
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
