latj
#1 Posted : Wednesday, May 26, 2010 5:11:49 AM(UTC)
latj
Dryed a load of clothes fine then put the 2nd load and dryer would not start,The timer runs the on push button clicks and thats all it will do! Any ideas?
#2 Posted : Wednesday, May 26, 2010 5:35:35 AM(UTC)
A model number may help others help you.
latj
#3 Posted : Wednesday, May 26, 2010 8:28:09 AM(UTC)
latj
Sorry! This is the model # Keys850LQ2 Found on the inside of the dryer door!
#4 Posted : Wednesday, May 26, 2010 2:35:04 PM(UTC)
Remove the rear panel and check the thermal fuse (#6 on the diagram) for continuity. If the fuse is open, replace the thermal cut-off and high limit thermostat (#8 & #15) and clean the vent line all the way to the outlet.
- The thermal fuse Part number: AP3133489
- The thermal cut-off kit (includes the high limit thermostat) Part number: AP3094244
latj
#5 Posted : Wednesday, May 26, 2010 3:53:33 PM(UTC)
latj
Thanks thats exactly what was wrong! Got it fixed!!
#6 Posted : Wednesday, May 26, 2010 8:44:00 PM(UTC)
You are welcome. We are glad you were able to fix it.
dryer wont run (Dryer Repair)
by gjack45pac 11/28/2015 9:40:28 AM(UTC)
by patriots 4/26/2015 10:21:36 AM(UTC)
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
dryer wont run control panel lights up (Dryer Repair)
by bobbijo 8/11/2013 2:13:57 PM(UTC)
Dryer wont run (Dryer Repair)
by wtester 12/3/2012 3:20:38 AM(UTC)
by jlp10 5/31/2011 4:34:08 PM(UTC)
by indybassin 2/21/2011 1:17:15 PM(UTC)
Maytag electric dryer wont run (Dryer Repair)
by crotonoil 12/9/2010 1:40:55 PM(UTC)
by jgiff@att.net 1/25/2010 6:33:35 AM(UTC)
Maytag dryer wont run (Dryer Repair)
by Dennisb 1/5/2010 2:14:39 PM(UTC)
dryer wont run after making squeaky noise (Dryer Repair)
by pattie 9/18/2009 10:59:40 PM(UTC)
by nairobi 9/16/2009 2:02:01 PM(UTC)
dryer wont run at all (Dryer Repair)
by neighbor 9/16/2009 7:04:39 AM(UTC)
by danielle 10/22/2008 5:55:37 PM(UTC)
