2 Pages12>
Jbore887
#1 Posted : 17 years ago
Jbore887
i own an old whirlpool ac unit and im tryin to find a port to recharge the freon can anyone please point me in the right direction
Magilla Gorilla
#2 Posted : 17 years ago
Magilla Gorilla
Is this a window unit?
Jbore887
#3 Posted : 17 years ago
Jbore887
yes it is a window unit
Magilla Gorilla
#4 Posted : 17 years ago
Magilla Gorilla
Some (most) older window units come with a port to fill the compressor with gas, then it's welded shut at the factory. In order to be able to charge these units, or even check the charge on them, new saddle ports need to be brazed on by someone with brazing experience.
Jbore887
#5 Posted : 17 years ago
Jbore887
that kinda stinks i was really hoping it was gonna be as easy as takin it apart and just charging it
SublimeMasterJW
#6 Posted : 17 years ago
SublimeMasterJW
You need an A-2 Tap. This tap will be placed on the fat pipe suction line coming from the compressor. Sand down the surface of the copper pipe before installing the valve. Charge the unit slowly till it holds 68.5 PSI. If you have a clamp on meter monitor the amp draw of the compressor while charging. Look on the nominclature tag and note the amp draw total when the unit is operating. No welding is needed with an A-2 tap. It has adapters to configure different size pipe and a tool to tighten the screws.
Magilla Gorilla
#7 Posted : 17 years ago
Magilla Gorilla
Or use an A-2 tap....I try to stay as far away as possible from working on window shakers....
SublimeMasterJW
#8 Posted : 17 years ago
SublimeMasterJW
I was born to work on window units.
Magilla Gorilla
#9 Posted : 17 years ago
Magilla Gorilla
You can keep your window shakers and I'll stick to rooftops and split systems...;)
misterfixall
#10 Posted : 17 years ago
misterfixall
so you are sugesting charging up an a/c with a possible leak in system?
I need help with literary work (General Talk)
by Fackbey201350 5 years ago
I need help (Washer Repair)
by Suehaye 7 years ago
i need help trouble shooting problem (Oven Repair (including Ranges and Cooktops))
by tom p817 9 years ago
by Adam1 12 years ago
LG Tromm Elec. Dryer is Dead. I need Help! (Dryer Repair)
by matt_a 13 years ago
I need help to figure out what's wrong with my thermostat/heating system (Heating, Ventilation, and Air Conditioning (HVAC))
by Newbie2 13 years ago
I need help to ID a part that feel to the floor (Dryer Repair)
by judo 14 years ago
I Need Help (Oven Repair (including Ranges and Cooktops))
by DNG 14 years ago
washer making noisy/ I need help (Washer Repair)
by kbl88 15 years ago
I need HELP URGENTLY I'm a women in need of a dishwasher (Dishwasher Repair)
by bwebb 15 years ago
by JAMES MASON 16 years ago
I NEED HELP whith rifrigerrator (Refrigerator & Freezer Repair)
by godzina 16 years ago
I need help replacing my heating element (Dryer Repair)
by saltrx 16 years ago
I need help to install dryer belt (Dryer Repair)
by shj288 16 years ago
door latch assembly fell out and I need help! (Dishwasher Repair)
by chellebyerly 16 years ago
2 Pages12>
