AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
I need help to ID a part that feel to the floor
Hi, while removing the front dryer panel a part feel to the floor without me seeing were it was attached to the dryer. The part is a small black box with no top and slits cut into the sides. I think it is used to cover some wires but am not certain. the breakdown diagram on for the front panel does not show it. any one have any ideas on where it goes on my dryer? next question is , i am replacing my drum support bearing on this dryer and do not know in which order a apply my new dryer drum slides (2 white and 2 green). My old drum support bearing was so worn that it nolonger had the drum slides attached so that i could see the order in which they were attached.
Thanks for any help you might be able to offer.
Here are your parts Replacement parts for General Electric DHDVH52EF0WW Electric dryer | AppliancePartsPros.com[COLOR="DarkRed"]The part is a small black box with no top and slits cut into the sides. I think it is used to cover some wires but am not certain. the breakdown diagram on for the front panel does not show it. any one have any ideas on where it goes on my dryer?[/COLOR] I do not know what this is, perhaps you can find it by looking through the above parts pages. [COLOR="DarkRed"] next question is , i am replacing my drum support bearing on this dryer and do not know in which order a apply my new dryer drum slides (2 white and 2 green).[/COLOR] Part number: AP631382
Click on the picture to get more info. Then click on the question on the above for info on which goes where. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
