2 Pages12>
Jbore887
#1 Posted : Tuesday, July 8, 2008 10:21:18 AM(UTC)
Jbore887
Groups ready for retrieval: Registered
i own an old whirlpool ac unit and im tryin to find a port to recharge the freon can anyone please point me in the right direction
Magilla Gorilla
#2 Posted : Tuesday, July 8, 2008 1:18:17 PM(UTC)
Magilla Gorilla
Is this a window unit?
Jbore887
#3 Posted : Tuesday, July 8, 2008 1:25:00 PM(UTC)
Jbore887
yes it is a window unit
Magilla Gorilla
#4 Posted : Tuesday, July 8, 2008 1:33:11 PM(UTC)
Magilla Gorilla
Some (most) older window units come with a port to fill the compressor with gas, then it's welded shut at the factory. In order to be able to charge these units, or even check the charge on them, new saddle ports need to be brazed on by someone with brazing experience.
Jbore887
#5 Posted : Tuesday, July 8, 2008 1:34:20 PM(UTC)
Jbore887
that kinda stinks i was really hoping it was gonna be as easy as takin it apart and just charging it
SublimeMasterJW
#6 Posted : Tuesday, July 8, 2008 6:23:12 PM(UTC)
SublimeMasterJW
You need an A-2 Tap. This tap will be placed on the fat pipe suction line coming from the compressor. Sand down the surface of the copper pipe before installing the valve. Charge the unit slowly till it holds 68.5 PSI. If you have a clamp on meter monitor the amp draw of the compressor while charging. Look on the nominclature tag and note the amp draw total when the unit is operating. No welding is needed with an A-2 tap. It has adapters to configure different size pipe and a tool to tighten the screws.
Magilla Gorilla
#7 Posted : Tuesday, July 8, 2008 6:55:32 PM(UTC)
Magilla Gorilla
Or use an A-2 tap....I try to stay as far away as possible from working on window shakers....
SublimeMasterJW
#8 Posted : Wednesday, July 9, 2008 11:18:48 AM(UTC)
SublimeMasterJW
I was born to work on window units.
Magilla Gorilla
#9 Posted : Wednesday, July 9, 2008 8:27:27 PM(UTC)
Magilla Gorilla
You can keep your window shakers and I'll stick to rooftops and split systems...;)
misterfixall
#10 Posted : Thursday, July 10, 2008 7:46:43 PM(UTC)
misterfixall
so you are sugesting charging up an a/c with a possible leak in system?
I need help with literary work (General Talk)
by Fackbey201350 4/17/2020 7:36:42 AM(UTC)
I need help (Washer Repair)
by Suehaye 1/3/2018 12:45:36 AM(UTC)
i need help trouble shooting problem (Oven Repair (including Ranges and Cooktops))
by tom p817 3/10/2016 3:45:12 AM(UTC)
by Adam1 10/13/2012 2:01:45 PM(UTC)
LG Tromm Elec. Dryer is Dead. I need Help! (Dryer Repair)
by matt_a 4/1/2012 8:27:02 AM(UTC)
I need help to figure out what's wrong with my thermostat/heating system (Heating, Ventilation, and Air Conditioning (HVAC))
by Newbie2 3/1/2012 8:15:13 AM(UTC)
I need help to ID a part that feel to the floor (Dryer Repair)
by judo 10/8/2011 9:55:46 PM(UTC)
I Need Help (Oven Repair (including Ranges and Cooktops))
by DNG 9/22/2011 5:31:51 AM(UTC)
washer making noisy/ I need help (Washer Repair)
by kbl88 12/10/2009 12:10:16 PM(UTC)
I need HELP URGENTLY I'm a women in need of a dishwasher (Dishwasher Repair)
by bwebb 10/28/2009 2:24:59 PM(UTC)
by JAMES MASON 10/6/2009 11:56:05 AM(UTC)
I NEED HELP whith rifrigerrator (Refrigerator & Freezer Repair)
by godzina 9/11/2009 8:03:44 AM(UTC)
I need help replacing my heating element (Dryer Repair)
by saltrx 9/8/2009 10:10:43 AM(UTC)
I need help to install dryer belt (Dryer Repair)
by shj288 6/25/2009 12:20:35 PM(UTC)
door latch assembly fell out and I need help! (Dishwasher Repair)
by chellebyerly 5/7/2009 8:54:34 AM(UTC)
2 Pages12>
