On spin cycle washer makes loud clunking noise, almost like it has an unbalanced load. I took all the clothes out and still heard the noise on the spin cycle,help me out.
Very likely the problem is a bad clutch (#5 on the diagram). You have to remove the washer cabinet, the pump and the motor, the agitator and the inner tub and drop off the transmission. You have to have a special spanner wrench to remove and reinstall the spanner nut (#12 on the diagram). - The clutch assembly Part number: AP3094537
Thank you , you were right , unfortunately part of the transmission housing was so worn down that it was not worth putting that much money into a 9 yr. old washer. Thanks again, whenever I have an appliance problem this will be the place I will turn to first.
