winthropenterprises
#1 Posted : Sunday, July 6, 2008 5:50:28 PM(UTC)
winthropenterprises
New to this , 1st my convection system stopped working in the oven which we just didnt use until we fixed it and now less than 2 weeks later the oven does not heat up at all . Can smell gas yet no heat . Everything else seems fine . Four burners on top all work properly . Any suggestions where to start?
LoginFreak
#2 Posted : Sunday, July 6, 2008 6:44:47 PM(UTC)
LoginFreak
If it's just the oven that is not working.
It could be the Igniter that is not working.
I replace many for all makes of ranges.
It's the most common part for ovens not working on gas ranges.
winthropenterprises
#3 Posted : Monday, July 7, 2008 11:48:58 AM(UTC)
winthropenterprises
I took out the bottom pan and see two burners and two igniters(assuming the igniters are the two that glow next to the burners)Its seems that the igniters are fine . They stay lit . The two burners go on seperately shortly aftger but it seems that the one burner goes out after not even a minute. Could it be the gas valve ? Are there seperate gas valves for each burner on the bottom ? If not ????? Thank you for your advice and time on this matter.
abadfish66
#4 Posted : Monday, July 7, 2008 11:58:54 AM(UTC)
abadfish66
The glow bar can glow, but if it does not reach and stay between 3.2-3.7 amps it needs replacing. You can put an ampprobe on one of the wires from the glow bar to measure this, or you could take a resistance reading of the glowbar. Resistance should be between 50-150ohms. If it is not within this the glowbar is bad and needs replacing.
Viking Range (VGR48-6G) Issue(s) (Oven Repair (including Ranges and Cooktops))
by Guest 9/26/2023 5:34:49 AM(UTC)
Viking range EVDSC4854GQSS - parts (Oven Repair (including Ranges and Cooktops))
by Guest 8/14/2023 5:31:20 AM(UTC)
Continuous sparking on viking range (Oven Repair (including Ranges and Cooktops))
by eschroeder01 1/2/2022 7:52:10 AM(UTC)
Viking range won't ignite when oven is hot (Oven Repair (including Ranges and Cooktops))
by osunick 6/5/2021 5:25:46 PM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Viking Range Flashing lights (Oven Repair (including Ranges and Cooktops))
by Stlgasman 12/28/2020 7:10:29 AM(UTC)
Viking range model VGR5606GQSS issues (Oven Repair (including Ranges and Cooktops))
by andpower 3/8/2020 10:18:05 AM(UTC)
Viking Range Age (Oven Repair (including Ranges and Cooktops))
by 22350 7/28/2019 3:05:52 PM(UTC)
Viking rangetop out of control flames (Oven Repair (including Ranges and Cooktops))
by tobloyd 12/30/2017 9:47:59 AM(UTC)
Viking range (Oven Repair (including Ranges and Cooktops))
by waydog 6/21/2016 3:53:57 AM(UTC)
Viking range spark module replacement (Oven Repair (including Ranges and Cooktops))
by dvernest 1/15/2016 4:08:42 PM(UTC)
anybody replace igniters on Viking Range? (Oven Repair (including Ranges and Cooktops))
by drbobfeelgood 11/5/2013 8:41:43 PM(UTC)
Viking Range Temperature Issues (Oven Repair (including Ranges and Cooktops))
by gaspower 7/8/2013 10:55:03 AM(UTC)
Viking range Griddle not lighting (Oven Repair (including Ranges and Cooktops))
by jdonal8447 6/29/2013 2:54:58 PM(UTC)
Viking Range -- stem on oven knob broken (Oven Repair (including Ranges and Cooktops))
by rbcole123 3/20/2013 9:57:02 AM(UTC)
