waydog
#1 Posted : Tuesday, June 21, 2016 3:53:57 AM(UTC)
waydog
Having big problems with stove top burner ignition. History: last year replaced module, worked fine for awhile then started to have difficulty igniting, spark but no flame. Then last week the two right burners didn't ignite at all. I took it apart and cleaned everything. Checked continuity on the spark wires, ground wire from the module and plug to make sure it was grounded. Now nothing sparks. I can hear a tiny spark noise when I turn a knob but not like the sound you hear when it is working properly. I took a piece of wire and screwed it to the frame that holds the burner in place and touched the top of the spark igniter, then turned knob on and it sparked. It only sparked on the side that I had the wire. I moved the wire to the left 2 burners and again I had spark on that side. I remove the wire and no spark. I believe I have a ground problem but not sure where. Or could the igniter not be grounded to where it is screwed in the frame. Or could one of the spark wire be bad. I have seen heat resistant wire on water heaters that lay on the steel drip pan arch even though you don't see any cracks or bare wire. Any help on this would be greatly appreciated. If I could I would tie a line to this thing and use it as an anchor. But can't afford to replace. thanks wayne
mettster
#2 Posted : Friday, December 30, 2016 2:00:02 PM(UTC)
mettster
Hi Wayne, ever solve this?
Viking Range (VGR48-6G) Issue(s) (Oven Repair (including Ranges and Cooktops))
by Guest 9/26/2023 5:34:49 AM(UTC)
Viking range EVDSC4854GQSS - parts (Oven Repair (including Ranges and Cooktops))
by Guest 8/14/2023 5:31:20 AM(UTC)
Continuous sparking on viking range (Oven Repair (including Ranges and Cooktops))
by eschroeder01 1/2/2022 7:52:10 AM(UTC)
Viking range won't ignite when oven is hot (Oven Repair (including Ranges and Cooktops))
by osunick 6/5/2021 5:25:46 PM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Viking Range Flashing lights (Oven Repair (including Ranges and Cooktops))
by Stlgasman 12/28/2020 7:10:29 AM(UTC)
Viking range model VGR5606GQSS issues (Oven Repair (including Ranges and Cooktops))
by andpower 3/8/2020 10:18:05 AM(UTC)
Viking Range Age (Oven Repair (including Ranges and Cooktops))
by 22350 7/28/2019 3:05:52 PM(UTC)
Viking rangetop out of control flames (Oven Repair (including Ranges and Cooktops))
by tobloyd 12/30/2017 9:47:59 AM(UTC)
Viking range spark module replacement (Oven Repair (including Ranges and Cooktops))
by dvernest 1/15/2016 4:08:42 PM(UTC)
anybody replace igniters on Viking Range? (Oven Repair (including Ranges and Cooktops))
by drbobfeelgood 11/5/2013 8:41:43 PM(UTC)
Viking Range Temperature Issues (Oven Repair (including Ranges and Cooktops))
by gaspower 7/8/2013 10:55:03 AM(UTC)
Viking range Griddle not lighting (Oven Repair (including Ranges and Cooktops))
by jdonal8447 6/29/2013 2:54:58 PM(UTC)
Viking Range -- stem on oven knob broken (Oven Repair (including Ranges and Cooktops))
by rbcole123 3/20/2013 9:57:02 AM(UTC)
Viking Range - No Gas Pressure (Oven Repair (including Ranges and Cooktops))
by macgiver 7/31/2012 6:08:35 PM(UTC)
