winthropenterprises
#1 Posted : Sunday, July 6, 2008 5:50:28 PM(UTC)
winthropenterprises
New to this , 1st my convection system stopped working in the oven which we just didnt use until we fixed it and now less than 2 weeks later the oven does not heat up at all . Can smell gas yet no heat . Everything else seems fine . Four burners on top all work properly . Any suggestions where to start?
LoginFreak
#2 Posted : Sunday, July 6, 2008 6:44:47 PM(UTC)
LoginFreak
If it's just the oven that is not working.
It could be the Igniter that is not working.
I replace many for all makes of ranges.
It's the most common part for ovens not working on gas ranges.
winthropenterprises
#3 Posted : Monday, July 7, 2008 11:48:58 AM(UTC)
winthropenterprises
I took out the bottom pan and see two burners and two igniters(assuming the igniters are the two that glow next to the burners)Its seems that the igniters are fine . They stay lit . The two burners go on seperately shortly aftger but it seems that the one burner goes out after not even a minute. Could it be the gas valve ? Are there seperate gas valves for each burner on the bottom ? If not ????? Thank you for your advice and time on this matter.
abadfish66
#4 Posted : Monday, July 7, 2008 11:58:54 AM(UTC)
abadfish66
The glow bar can glow, but if it does not reach and stay between 3.2-3.7 amps it needs replacing. You can put an ampprobe on one of the wires from the glow bar to measure this, or you could take a resistance reading of the glowbar. Resistance should be between 50-150ohms. If it is not within this the glowbar is bad and needs replacing.
Viking rangetop out of control flames (Oven Repair (including Ranges and Cooktops))
by tobloyd 12/30/2017 9:47:59 AM(UTC)
Viking range (Oven Repair (including Ranges and Cooktops))
by waydog 6/21/2016 3:53:57 AM(UTC)
Viking range spark module replacement (Oven Repair (including Ranges and Cooktops))
by dvernest 1/15/2016 4:08:42 PM(UTC)
anybody replace igniters on Viking Range? (Oven Repair (including Ranges and Cooktops))
by drbobfeelgood 11/5/2013 8:41:43 PM(UTC)
Viking Range Temperature Issues (Oven Repair (including Ranges and Cooktops))
by gaspower 7/8/2013 10:55:03 AM(UTC)
Viking range Griddle not lighting (Oven Repair (including Ranges and Cooktops))
by jdonal8447 6/29/2013 2:54:58 PM(UTC)
Viking Range -- stem on oven knob broken (Oven Repair (including Ranges and Cooktops))
by rbcole123 3/20/2013 9:57:02 AM(UTC)
Viking Range - No Gas Pressure (Oven Repair (including Ranges and Cooktops))
by macgiver 7/31/2012 6:08:35 PM(UTC)
viking range burner clicks even when lit (Oven Repair (including Ranges and Cooktops))
by mattbiel 12/26/2011 12:49:40 PM(UTC)
viking range (Oven Repair (including Ranges and Cooktops))
by Bobbie Stead 11/8/2011 6:35:51 AM(UTC)
Viking Range (Oven Repair (including Ranges and Cooktops))
by Divi424 9/30/2010 8:09:19 AM(UTC)
viking range broiler broken (Oven Repair (including Ranges and Cooktops))
by inahi 1/5/2010 8:49:47 PM(UTC)
replace the oven ignitor on a viking range (Oven Repair (including Ranges and Cooktops))
by jm81204 11/14/2009 4:05:21 AM(UTC)
Viking Range dreaded ignitor (Oven Repair (including Ranges and Cooktops))
by ISLAND 9/17/2009 11:19:46 PM(UTC)
Viking range top trips GFI (Oven Repair (including Ranges and Cooktops))
by Dscully 8/31/2009 12:56:12 PM(UTC)
