I have the following problem. When the washer goes to spin cycle, It starts to wobble & vibrate a lot so much that I have to shut off the washer. It shows error code 'uL' . I have balanced the unit the level is good. Plus I tried to do it without any load. It still does the same. Only while it is spinning. While washing it is fine. So please advice. Thanks
