pipefitter
#1 Posted : Sunday, June 29, 2008 6:12:19 PM(UTC)
pipefitter
Wife washed anail wrecked Outer tub leaks water. Could not Get model # to come up on parts finder. When to another sight and got part # but does not show picture and I am that type of guy.
#2 Posted : Monday, June 30, 2008 1:38:52 PM(UTC)
Can you be more specific on the problem? If you could not find the model number of the washer, what means the model number NAV5800aww you posted here?
pipefitter
#3 Posted : Monday, June 30, 2008 6:39:13 PM(UTC)
pipefitter
Thanks for the reply the model # is NAV5800AWW Amana clothes washer when I put the modle # in it never came up. So I went to another sight and looked up manufacture # of the outter tub but to be on the safe side I wanted to see a parts break down and could not get the model# to pull up it gave me three outher choices of model #'s and none of the #'s of thoese outer tubs matched to the one the for the manufacture cross referance # on this sight so I need help before I spend the money on an outer tub and get the wrong one shiped. sorry that the frist Question was not enough information.
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/7/2022 6:29:02 AM(UTC)
Frigidiare Gallery High temp alert. Need help troubleshooting. (Refrigerator & Freezer Repair)
by GregWood 8/28/2022 7:47:25 PM(UTC)
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
need help with model number (Oven Repair (including Ranges and Cooktops))
by onadraw 7/2/2021 10:01:12 AM(UTC)
Need Help With Frigidaire FGHS2631PF4A (Refrigerator & Freezer Repair)
by BrianR1 3/2/2021 1:46:20 PM(UTC)
I need help with literary work (General Talk)
by Fackbey201350 4/17/2020 7:36:42 AM(UTC)
GE WASHER NEED HELP(SOLVED) (Dishwasher Repair)
by Covenant29204 9/8/2019 9:51:57 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
