Wife washed anail wrecked Outer tub leaks water. Could not Get model # to come up on parts finder. When to another sight and got part # but does not show picture and I am that type of guy.
Can you be more specific on the problem? If you could not find the model number of the washer, what means the model number NAV5800aww you posted here?
Thanks for the reply the model # is NAV5800AWW Amana clothes washer when I put the modle # in it never came up. So I went to another sight and looked up manufacture # of the outter tub but to be on the safe side I wanted to see a parts break down and could not get the model# to pull up it gave me three outher choices of model #'s and none of the #'s of thoese outer tubs matched to the one the for the manufacture cross referance # on this sight so I need help before I spend the money on an outer tub and get the wrong one shiped. sorry that the frist Question was not enough information.
