The plastic roller bushings on the oven door hinges are broken and the door will not open easily. It appears that the entire hinge assemblies will to be replaced. Trying to locate them and get a price. Thank you. Edd
Hi Edd, The part number for the left side door hinge is AP2020720 and you can buy it for $20.76 The part number for the right side door hinge is AP2020721 and you can buy it for $20.75 Gene.
Do the hinges work for the Kenmore Model #911.3652191 as well? Probably, but I want to make sure. Thanks
Originally Posted by: hattg  Do the hinges work for the Kenmore Model #911.3652191 as well? Probably, but I want to make sure. Thanks Yes, you can use the same part numbers. Gene.
Originally Posted by: Gene  Hi Edd, The part number for the left side door hinge is AP2020720 and you can buy it for $20.76 The part number for the right side door hinge is AP2020721 and you can buy it for $20.75 Gene. Thanks Gene: but I am getting a price of $ 28.39 plus $ 6.95 shipping on appliancePartsPros.com. Is there a coupon code or something that I should use? Thanks, Joe
