EEE
#1 Posted : Wednesday, June 25, 2008 6:59:06 PM(UTC)
EEE
The plastic roller bushings on the oven door hinges are broken and the door will not open easily. It appears that the entire hinge assemblies will to be replaced. Trying to locate them and get a price. Thank you. Edd
#2 Posted : Thursday, June 26, 2008 3:06:49 PM(UTC)
Hi Edd,
The part number for the left side door hinge is AP2020720 and you can buy it for $20.76
The part number for the right side door hinge is AP2020721 and you can buy it for $20.75
hattg
#3 Posted : Wednesday, January 27, 2010 6:36:49 PM(UTC)
hattg
Do the hinges work for the Kenmore Model #911.3652191 as well? Probably, but I want to make sure.
#4 Posted : Wednesday, January 27, 2010 7:24:12 PM(UTC)
Yes, you can use the same part numbers.
jabutler
#5 Posted : Tuesday, December 8, 2015 5:27:43 AM(UTC)
jabutler
Hi Edd,
Thanks Gene: but I am getting a price of $ 28.39 plus $ 6.95 shipping on appliancePartsPros.com. Is there a coupon code or something that I should use?
Thanks,
Joe
Guest (5)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
No lockouts on Gas oven door hinges (Oven Repair (including Ranges and Cooktops))
by sendto 3/16/2018 8:49:42 AM(UTC)
Oven door hinges (Oven Repair (including Ranges and Cooktops))
by prcummings 1/20/2018 3:29:04 PM(UTC)
by llfraser 6/14/2013 7:19:47 AM(UTC)
by Ovenblues 4/12/2013 10:39:26 AM(UTC)
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 10/4/2012 8:50:36 AM(UTC)
Maytag oven door hinges replacement (Oven Repair (including Ranges and Cooktops))
by dennispandolfino 7/11/2012 2:25:00 PM(UTC)
by pastorapodaca 5/4/2011 9:25:06 AM(UTC)
Oven Door Hinges Replaced, Now Bad Again (Oven Repair (including Ranges and Cooktops))
by Mikeh14 2/10/2009 7:56:40 AM(UTC)
Oven Door Hinges (Oven Repair (including Ranges and Cooktops))
by GylanAllen 12/19/2008 9:51:31 AM(UTC)
Replace oven door hinges (Oven Repair (including Ranges and Cooktops))
by charliesue 8/8/2008 4:05:57 PM(UTC)
