EEE
#1 Posted : 17 years ago
EEE
The plastic roller bushings on the oven door hinges are broken and the door will not open easily. It appears that the entire hinge assemblies will to be replaced. Trying to locate them and get a price. Thank you. Edd
#2 Posted : 17 years ago
Hi Edd,
The part number for the left side door hinge is AP2020720 and you can buy it for $20.76
The part number for the right side door hinge is AP2020721 and you can buy it for $20.75
hattg
#3 Posted : 15 years ago
hattg
Do the hinges work for the Kenmore Model #911.3652191 as well? Probably, but I want to make sure.
#4 Posted : 15 years ago
Yes, you can use the same part numbers.
jabutler
#5 Posted : 9 years ago
jabutler
Hi Edd,
Thanks Gene: but I am getting a price of $ 28.39 plus $ 6.95 shipping on appliancePartsPros.com. Is there a coupon code or something that I should use?
Thanks,
Joe
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 5 years ago
No lockouts on Gas oven door hinges (Oven Repair (including Ranges and Cooktops))
by sendto 7 years ago
Oven door hinges (Oven Repair (including Ranges and Cooktops))
by prcummings 7 years ago
by llfraser 12 years ago
by Ovenblues 12 years ago
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 12 years ago
Maytag oven door hinges replacement (Oven Repair (including Ranges and Cooktops))
by dennispandolfino 13 years ago
by pastorapodaca 14 years ago
Oven Door Hinges Replaced, Now Bad Again (Oven Repair (including Ranges and Cooktops))
by Mikeh14 16 years ago
Oven Door Hinges (Oven Repair (including Ranges and Cooktops))
by GylanAllen 16 years ago
Replace oven door hinges (Oven Repair (including Ranges and Cooktops))
by charliesue 16 years ago
