EdMarquez
#1 Posted : Saturday, June 21, 2008 11:34:19 AM(UTC)
EdMarquez
My dryer heats up when it's first started but when it stops for any reason or after certain time running it will stop heating. The igniter goes read hot and very bright but there is no gas ignition. I replace all of the sensors; temperature sensors and flame sensor and the problem still continues. I understand that it might be the coils on the gas valve. My question is how do I know that it is the coils and not the valve itself. I removed the gas valve and exited one of the coils and it works fine. The second coil it does not but if I switch the coils the one that did not work before works now and the one that did work befoer it does not in the new position. Is this an indication that the problem is the valve itself? I'm at a lost and ready to purchase a new valve (Part number 504091) but I wonder if the coils (Part number AP3094251) alone will do the job. Another question, if I purchase the valve Part number 504091, does it comes with the coils or I have to buy them separately? Please help.
Thanks,
Ed
SublimeMasterJW
#2 Posted : Saturday, June 21, 2008 11:58:28 AM(UTC)
SublimeMasterJW
Replace the coils and your problems will be over. What happens is theses puppys get hot and fail, given time to cool off they work once and then quit. The eventually cool down and work again once or twice and die again. replace these guys:a lid switch quick connect.jpg
SublimeMasterJW attached the following image(s):
EdMarquez
#3 Posted : Monday, June 30, 2008 8:40:07 AM(UTC)
EdMarquez
Great. Thanks, I replaced the coils and the dryer is now working great.:D
harleyfxe
#4 Posted : Thursday, October 1, 2009 11:55:22 AM(UTC)
harleyfxe
My dryer is doing the same thing. I just put in the new coils and no change. What would be the next logical option. The glow plug still lights up bright and the flame ignites, but goes out almost instantly. With the old coils it would at least stay on for about 30 sec or so.
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
