Dryer won't start when I turn switch, I opened back panel in dryer and found the drive belt broken, is this related to the dryer not starting or is it just another part that needs to be replaced? Also how do you re-install belt, did look at belt drive diagrams which weren't of much help, need step by step written instruction if possible. Thanks:confused:
Yes the dryer will not start without a belt, step by step written instruction will come with a new belt. There might also be a pully that is laying on the bottom of the dryer also.
