I have tested the icemaker for power and read 98 volts AC at the connector. I hooked 110volts to the proper terminals and it still will not make ice. The motor works fine with power. Is there a way of testing the sensors and putting it through a test cycle to determine the problem? I have manually filled up the unit with water. It has frozen but will not start the cyle. If I put power to the fill valve it works fine and water comes out of the line in the freezer. The heater for the tray warms up OK to release the ice for dispensing. What else can I do?
Russell,
The model number you posted does not come up. Verify and repost it.
Gene. Gene the model number of the Whirlpool Refrigerator is GC3PHEXNS03. The number on the ice maker control module is S106 2198597 LR5010. Thank you. Russell
