My ice maker stopped producing ice. The water dispenser works fine.
I replaced the intake valves for the ice maker/water dispenser. I had checked the ohms before replacement and the one side seemed low. I checked the new valves and they are higher than the original, however I don't think that was the problem.
The ice maker it's self seems to work. The ice sensor bar moves up and down and the tines for dispensing the ice seem to work. But no ice.
There is no sound like previously of the valve opening and closing for the water coming into the ice maker.
Please, what else could it be the problem? And how would check to see if that is the problem.
The functions of water dispenser are fine. Filters are fine but the problem is that water not going into ice making tray. This problem came so many times that's why I came across Portable Ice Maker but would you like to have more suggestion more recommendations.
