Russell Lammer
#1 Posted : Monday, March 15, 2010 6:52:20 AM(UTC)
Russell Lammer
I have tested the icemaker for power and read 98 volts AC at the connector. I hooked 110volts to the proper terminals and it still will not make ice. The motor works fine with power. Is there a way of testing the sensors and putting it through a test cycle to determine the problem? I have manually filled up the unit with water. It has frozen but will not start the cyle. If I put power to the fill valve it works fine and water comes out of the line in the freezer. The heater for the tray warms up OK to release the ice for dispensing. What else can I do?
#2 Posted : Monday, March 15, 2010 3:07:16 PM(UTC)
Russell,
The model number you posted does not come up. Verify and repost it.
Russell Lammer
#3 Posted : Tuesday, March 16, 2010 2:05:58 AM(UTC)
Russell Lammer
Russell,
Gene the model number of the Whirlpool Refrigerator is GC3PHEXNS03. The number on the ice maker control module is S106 2198597 LR5010.
Thank you. Russell
#4 Posted : Tuesday, March 16, 2010 5:16:15 PM(UTC)
Russell,
You can check the optics as described in one of our previous posts: http://forum.appliancepartspros...makes-little-no-ice.html, but the low voltage at the plug shows that they most likely are bad.
- The optic boards kit Part number: AP3137510
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
