what part do i need to fix this? The fridge part is not sealing at all and it seems like the freezer door does not have a good suction whrn i close it.
Here are your parts Replacement parts for csx24dlp-1 models | AppliancePartsPros.comCheck to see if the seal is binding on the hinge side when the door closes. If yes, clean the unit's frame and the seal. Them put a light coat of grease along that side of the seal so it will slip. Check the cam's. See Item 16 in Section 1 and Item 451 in Section3. Click on the pictures for a better view. Make sure the unit is level or leaning slightly to the back. |
THIS FORUM IS DEAD!!!!!!! |
