carl reed
#1 Posted : Friday, March 5, 2010 6:25:05 PM(UTC)
carl reed
what part do i need to fix this? The fridge part is not sealing at all and it seems like the freezer door does not have a good suction whrn i close it.
#2 Posted : Saturday, March 6, 2010 1:31:17 AM(UTC)
Replacement parts for csx24dlp-1 models | AppliancePartsPros.com
Check to see if the seal is binding on the hinge side when the door closes.
If yes, clean the unit's frame and the seal. Them put a light coat of grease along that side of the seal so it will slip.
Check the cam's. See Item 16 in Section 1 and Item 451 in Section3.
Click on the pictures for a better view.
Make sure the unit is level or leaning slightly to the back.
Kenmore Fridge Door not sealing (Refrigerator & Freezer Repair)
by frogprincess2 8/7/2014 9:31:09 PM(UTC)
Bottom freezer door not sealing properly (Refrigerator & Freezer Repair)
by nickd61 5/12/2013 6:45:58 PM(UTC)
refridgerator door not sealing well (Refrigerator & Freezer Repair)
by mistyystim 8/11/2011 4:57:49 AM(UTC)
Kenmore side-by-side door not sealing properly (Refrigerator & Freezer Repair)
by CKuhlman 5/29/2011 4:35:59 PM(UTC)
Bottom Freezer door not sealing (Refrigerator & Freezer Repair)
by mbs235 2/16/2011 2:21:45 PM(UTC)
Door not sealing properly, tweaked door? (Refrigerator & Freezer Repair)
by coachant 11/4/2010 9:43:19 PM(UTC)
Upright freezer door not sealing / staying closed tight (Refrigerator & Freezer Repair)
by Tsunamiron 5/7/2010 11:54:46 AM(UTC)
Freeze door not sealing (Refrigerator & Freezer Repair)
by southsidequeen 6/19/2009 9:22:31 AM(UTC)
by cbs24 12/11/2008 1:30:31 PM(UTC)
Ice on coils in freezer; Refridge door not Sealing (Refrigerator & Freezer Repair)
by Julie Riggleman 10/1/2008 6:47:57 AM(UTC)
Door not sealing with new gasket (Refrigerator & Freezer Repair)
by brookdoyle 12/2/2007 8:59:27 PM(UTC)
by RadRick 8/8/2007 4:03:15 PM(UTC)
