southsidequeen
#1 Posted : Friday, June 19, 2009 9:22:31 AM(UTC)
southsidequeen
When I shut the freezer door I think it should create some suction but it does not. What should I do?
#2 Posted : Friday, June 19, 2009 3:27:28 PM(UTC)
Put a $ bill between the door seal and the door frame and close the door. If the bill stays firm and do not fall then the door sealed properly.
southsidequeen
#3 Posted : Friday, June 19, 2009 7:32:14 PM(UTC)
southsidequeen
After further review the gasket is broken at the bottom of the freezer. If I replace the will it fix the problem. Can a quick fix be to glue it back in place.
southsidequeen
#4 Posted : Saturday, June 20, 2009 6:24:48 AM(UTC)
southsidequeen
The $ bill did stay put
#5 Posted : Saturday, June 20, 2009 3:09:07 PM(UTC)
Originally Posted by: southsidequeen Go to Quoted Post
...After further review the gasket is broken at the bottom of the freezer...
If there is no condensation inside the refrigerator I'm assuming the damage is not very big. You probably can tape the broken piece.
southsidequeen
#6 Posted : Tuesday, June 23, 2009 10:32:35 AM(UTC)
southsidequeen
There is condensation at the top of freezer. When I open the freezer there are small icicles on the door and frost on the top.
Guest (4)
