jdaly
#1 Posted : Monday, March 1, 2010 9:11:18 AM(UTC)
jdaly
My Neptune dryer has started making an intermittant squeaking/squeeling noise. I have looked at your model parts list and think that likely this noise is coming from either the drum roller assemblies or a bearing idler assembly. In the Maytag book attached to another question thread, it appears their is a Maytag oil that is specified. I need to know if these items can be oiled/greased or if new parts are required. If the drum rollers need to be replaced which specific parts do I oreder and the same for the bearing item assembly. Please help me isolate the method to proceed.
magician59
#2 Posted : Monday, March 1, 2010 10:35:45 AM(UTC)
magician59
The inside of the dryer is not a good place to have grease or oil. Over some time, the ling will just gum up with te oil and cause the problem to be worse. If the noise you hear is high pitched, chances are it's the idler.Part number: AP4373393
If it's more like a low rumble, the rollers probably need to be replacedPart number: AP4008534
, or the blower wheel is loose on the motor shaftPart number: AP4043082
. A scraping, or squealing sound would indicate the front bearings (nylon glides)Part number: AP4037304
jdaly
#3 Posted : Monday, March 1, 2010 2:33:51 PM(UTC)
jdaly
I read through your response and ordered parts which most fit the probable issue. I will let you know after I install the parts if I bought the right parts. Thanks again for your response and pictures which help a lot.
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
Maytag Neptune wont high spin under load (Washer Repair)
by jim20j 2/24/2023 9:23:15 AM(UTC)
Maytag Neptune Stacklable (Washer Repair)
by johnafoy@yahoo.com 2/7/2023 11:34:24 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
maytag neptune MAH21PD tumbles during spin (Washer Repair)
by joedonovan 11/22/2021 4:27:39 PM(UTC)
maytag neptune MAH21PD (Washer Repair)
by Guest 11/22/2021 4:23:11 PM(UTC)
Maytag Neptune MAH5500AWW (Washer Repair)
by Bubdad1 4/19/2021 4:49:41 AM(UTC)
Maytag Neptune DC (Drying Center) gas dryer mcg8000aww Flame not staying on (Dryer Repair)
by chanash 12/15/2020 3:00:11 PM(UTC)
maytag neptune motor spins too fast (Washer Repair)
by jbmur 11/27/2020 7:25:55 PM(UTC)
Maytag Neptune MAH8700 Repair (Control Board) (Washer Repair)
by kicaza 11/17/2020 9:45:19 AM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Maytag Neptune runs cold and hot but not warm (Washer Repair)
by mikecinmaine 7/25/2020 6:32:28 AM(UTC)
