Hello,
I have a GE Triton Dishwasher that will drain, I hear and fell it drain, but will not drain the water completely out. It will leave water up to the elements. I have checked the fine filter at the very back, bottom of the dishwasher and found nothing. I checked the piston and nut assembly and it looked perfectly fine. I took apart the sump and found nothing down int he hole. It was very dirty water though.
Any ideas?
Thanks,
Joe
A model number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A model number may help others help you. Sorry about that the model number is GSD5560G01SS Thanks
