joe3523
#1 Posted : Sunday, February 21, 2010 9:50:35 AM(UTC)
joe3523
Hello,
I have a GE Triton Dishwasher that will drain, I hear and fell it drain, but will not drain the water completely out. It will leave water up to the elements. I have checked the fine filter at the very back, bottom of the dishwasher and found nothing. I checked the piston and nut assembly and it looked perfectly fine. I took apart the sump and found nothing down int he hole. It was very dirty water though.
Any ideas?
Thanks,
Joe
#2 Posted : Monday, February 22, 2010 6:19:21 AM(UTC)
A model number may help others help you.
joe3523
#3 Posted : Tuesday, February 23, 2010 4:22:46 AM(UTC)
joe3523
Sorry about that the model number is GSD5560G01SS
#4 Posted : Tuesday, February 23, 2010 7:11:19 AM(UTC)
Here are the parts
Motor - pump mechanism replacement parts for General Electric GSD5560G01SS Dishwasher | AppliancePartsPros.com
Can you feel/hear the drain pump running?
Disconnect the drain hose from the house plumbing.
Often it will clog where the hose goes over the fitting.
You could try draining it into a pail to eliminate a house plumbing clog as the cause. Just be sure to hold the drain hose securely in the pail and put a towel over it's top, unless you want a shower.
GE triton Dishwasher won't fully drain (Dishwasher Repair)
by Porter123 8/11/2014 12:15:53 PM(UTC)
GE Triton Dishwasher does not wash/rinse (Dishwasher Repair)
by mosierap 4/9/2012 3:10:17 PM(UTC)
GE Triton Dishwasher Does not drain out completely (Dishwasher Repair)
by rkt 7/29/2010 9:36:51 PM(UTC)
GE Triton dishwasher loud noise after draining (Dishwasher Repair)
by fkong186 10/20/2009 1:04:47 PM(UTC)
Replacing motor on GE Triton dishwasher (Dishwasher Repair)
by Gordon Casey 1/22/2008 6:20:16 PM(UTC)
