RonSheehan
#1 Posted : Saturday, February 20, 2010 10:09:56 AM(UTC)
RonSheehan
My dryer (whirlpool model # LHE580 0N0 serial # M95024350)was not heating so they told me to replace the thermal fuse. ordered a thermal fuse (part # 3390719) but now i can not find a diagram for my dryer anywhere. please help me find where to install it, thanks
Ron
sidfink43
#2 Posted : Monday, February 22, 2010 6:57:40 AM(UTC)
sidfink43
Take off the back and see if it is not right there.
You should know that the problem is not in the thermal fuse if the machine continues to run.
First check to make sure you are getting 120v to each side of the connection block. Then disconnect the machine to work on it.
I would change out the thermostat, high limit thermostat and thermal cutoff if one of them is bad. Also clean out the internal and external vent areas thoroughly as that is what usually causes the fuses to blow.
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
Dryer does not heat, but runs, all parts seem to be good (Dryer Repair)
by discgolfdoug 10/14/2012 8:01:10 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Kenmore H3 Dryer does not heat (Dryer Repair)
by tim75 8/7/2012 10:12:46 AM(UTC)
by tomromeyn7 6/3/2012 2:57:52 PM(UTC)
Electric dryer does not heat. (Dryer Repair)
by Wtucker 4/19/2012 11:10:26 AM(UTC)
by thabersaat 2/27/2012 11:10:06 AM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by lingo622 9/22/2011 12:03:52 PM(UTC)
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 7/28/2011 10:55:43 AM(UTC)
by nwiccauto 6/16/2011 10:02:50 AM(UTC)
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 5/19/2011 2:34:34 PM(UTC)
