A friend gave me this refer which is in overall good condition. I have noticed that ice forms on the seams where the doors meet in the middle. I have included a picture that should tell the story. Can you tell me what that might be caused by? fred1 attached the following image(s):
You might have a mullion heater in there, if so and you have an energy saver switch, just turn it on, frost will go away. Also, you might have a bad door gasket. Slip a dollar between the gasket and door trim, if easy to pull out, you have a bad door gasket.
