stressman4
#1 Posted : Thursday, May 8, 2008 7:25:15 PM(UTC)
stressman4
My GE dishwasher will not drain completely, here is what I did so far; I have removed the hose and checked for obstructions, I have no air gap but the hose does attach to the garbage disposer. I confirmed the disposer connection is clear . I checked the hoses and flapper valves from the boost pump for obstructions. I have replaced the pump which is identified as the drain boost pump. I changed the boost pump because when I first looked in it I found some broken glass fragments and it appeared the impeller was gouged up. After running many cycles and observing the operation it seems as though the boost pump may not be running long enough for the machine to drain. Please HELP!!
#2 Posted : Friday, May 9, 2008 3:13:22 PM(UTC)
Perform the same troubleshooting as recommended in one of previous posts: http://forum.appliancepartspros...er-ii-fails-drain-2.html and post the results.
Here are the break down diagrams for the GE dishwasher Model GSD5620D00BB
Jackobjio
#3 Posted : Wednesday, April 3, 2013 6:08:04 PM(UTC)
Jackobjio
I'm stuck with the same freaking problem!!! WTF!!! I trusted GE!
Sparhawk21
#4 Posted : Wednesday, January 1, 2014 12:17:13 PM(UTC)
Sparhawk21
You said it's connected to the garbage disposal...I know this is an old post but did you take the plunger out of the garbage disposal?
DanV.
#5 Posted : Monday, March 24, 2014 7:38:23 AM(UTC)
DanV.
How do you plunge it,
DanV.
#6 Posted : Monday, March 24, 2014 7:39:36 AM(UTC)
DanV.
How do you plunge it.
dannyro
#7 Posted : Tuesday, January 27, 2015 12:33:33 PM(UTC)
dannyro
Hold the start button for 5 seconds it will drain
