My GE dishwasher will not drain completely, here is what I did so far; I have removed the hose and checked for obstructions, I have no air gap but the hose does attach to the garbage disposer. I confirmed the disposer connection is clear . I checked the hoses and flapper valves from the boost pump for obstructions. I have replaced the pump which is identified as the drain boost pump. I changed the boost pump because when I first looked in it I found some broken glass fragments and it appeared the impeller was gouged up. After running many cycles and observing the operation it seems as though the boost pump may not be running long enough for the machine to drain. Please HELP!!
I'm stuck with the same freaking problem!!! WTF!!! I trusted GE!
You said it's connected to the garbage disposal...I know this is an old post but did you take the plunger out of the garbage disposal?
Originally Posted by: Sparhawk21  You said it's connected to the garbage disposal...I know this is an old post but did you take the plunger out of the garbage disposal? How do you plunge it,
Hold the start button for 5 seconds it will drain
