Discuss
GE Profile Quiet Power II fails to drain
 in
Dishwasher Repair
Joe, Remove the filter frame (#543 on the break down diagram) and unscrew the piston & nut assembly (#564 on
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Profile Quiet Power II fails to drain
  #11 (permalink)
Old 05-09-2008, 04:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Joe,
Remove the filter frame (#543 on the break down diagram) and unscrew the piston & nut assembly (#564 on the break down diagram). Looking at the part picture, compare condition of the cone center piece and replace the piston & nut assembly if necessary.
- The part number for the piston & nut assembly is AP2617344
__________________
  #12 (permalink)
Old 10-19-2008, 08:48 AM
stevie baa stevie baa is offline
Junior Member
stevie baa is on a distinguished road
Default same problem
Hi there,
i'm visiting my sister and she has the same line of dishwasher.
same issue of not draining on the final cycle. they tell me they took apart and inspected all the external and internal plumbing for cloggs and found nothing.
the cycle does drain at points of the cycle where it exchanges some of the water in the tub. as stated in the last post we can drain it by starting a new cycle and pressing reset.
i believe the problem is in the controller. since all the mechanicals seem to be working.
does anyone know how the do a hard reset on the controller board? some type of combination key press, if possible?
thanks for your help,
steve baader
  #13 (permalink)
Old 10-26-2008, 05:54 PM
KennBur KennBur is offline
Junior Member
KennBur is on a distinguished road
Default
Steve,
You might want to take a look at the several other threads with the same general subject - GE dishwasher won't empty.
Seems the problem can be due to about five different things -- mostly mechanical.
Reference this breakdown diagram and parts list for general info:
Model GSD4030Z07WW
The causes include the air gap gizmo (rarely found since 1995), the drain hose clogged up, the Piston assembly for check valve and its nut Piston & nut, Body valve & check assembly and, finally, the pump and motor assembly. If you've replaced all that stuff, you need a new machine and.or a certified GE repair person.
Good luck!
Kenn
P.S. I've been messing with my machine for some 5 weeks, off and on, and it still doesn't drain! My wife is about to buy a Whirlpool DU1055XTS[Q] Whirlpool DU1055XTS(Q) | ConsumerSearch.com to replace the GE.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile washer doesn't drain shellface Washer Repair 6 01-05-2009 11:54 AM
GE Profile dead, power surge Simbot Microwave Repair 17 07-26-2008 03:18 PM
GE Triton Quiet Power III PJB Dishwasher Repair 6 04-04-2008 08:14 PM
GE Profile DW won't drain or spray JimChooz Dishwasher Repair 3 02-18-2008 08:09 PM
Whirlpool Quiet Partner III Does Not Drain volant Dishwasher Repair 6 12-28-2007 03:17 AM
