htvdo105
#1 Posted : Friday, January 29, 2010 11:44:46 AM(UTC)
htvdo105
The freezer is getting abuild up on the back of the freezer, it is suppost to be frost free. also the refrigerator doesnt seem to be as cold as it has been
#2 Posted : Friday, January 29, 2010 1:35:25 PM(UTC)
Here are your parts, Your model number was short several digits so i used SABAAAA
Replacement parts for TFX20S models | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 6/18/2022 7:38:51 AM(UTC)
Just bought new side by side refrigerator but doesn't get cold enough (Refrigerator & Freezer Repair)
by Hotlynx16 3/28/2022 2:47:44 PM(UTC)
Admiral side by side refrigerator external drip drain tray (Appliance Parts)
by Paul Bridges 1/14/2021 10:28:34 AM(UTC)
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
GE Profile Side by Side Refrigerator Model ESS25XGMB (2001) not cooling (Refrigerator & Freezer Repair)
by boxer 7/14/2019 7:19:21 PM(UTC)
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 2/21/2019 7:14:22 PM(UTC)
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 6/28/2018 8:18:44 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
Side by side refrigerator keeps turning on and off (Refrigerator & Freezer Repair)
by Rasenganguy 9/27/2016 6:43:34 PM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9/17/2015 11:52:33 AM(UTC)
Side by side refrigerator not cooling. (Refrigerator & Freezer Repair)
by Jms55 1/26/2015 12:24:12 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
