The microwave stopped working.....no power....no on light...
the oven works, all lights work except the on (for Microwave)
Is there a reset button... or is that too simple???????
help any suggestions at this point.
Groups ready for retrieval: Registered
The MW will be controoled by it's own fuse. Most likely a 20 amp. Usually a fuse blows for a reason. Sometimes, albeit rare they will just blow. I would locate the fuse and replace it one time. If it blows again then you have a deeper problem.
