nbtxphil
#1 Posted : Monday, January 18, 2010 6:48:35 PM(UTC)
nbtxphil
At first drying took longer than normal. Now it does not heat at all. The digital display jumps from 1:36 to 1:52 then goes in a circle after a few minutes. Checked breaker and venting both ok. If heating element is bad should the thermostats and the thermistor also be replaced. Or should I call a repair man.
#2 Posted : Tuesday, January 19, 2010 4:30:06 AM(UTC)
Here is the parts breakdown, includes a wiring diagram
Replacement parts for MAYTAG MDE2400AYW Dryer - Ele | AppliancePartsPros.com
I could not find a tech sheet for this unit
The following may help
http://www.servicematters.com/maytag_library/docs/16023432.pdf
http://www.servicematters.com/maytag_library/docs/IDL-0002A-B.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0076A-B.pdf
http://www.servicematters.com/maytag_library/docs/ITDL-0037-B.pdf
[COLOR="Blue"]Checked breaker and venting both ok.[/COLOR]
Did you actually measure the voltage?
[COLOR="Blue"]If heating element is bad should the thermostats and the thermistor also be replaced.[/COLOR]
I would check them with a meter first.
[COLOR="Blue"]
Or should I call a repair man.[/COLOR]
Depends on how handy you are !!
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 10/10/2016 5:42:01 AM(UTC)
My Dryer not drying (Dryer Repair)
by anikabrown 3/29/2016 3:57:03 AM(UTC)
Dryer not Drying (Dryer Repair)
by BraxLimbo 11/12/2015 11:08:58 PM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 5/30/2015 3:31:39 AM(UTC)
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 3/26/2015 5:50:26 PM(UTC)
