Al
afresquez
#1 Posted : Monday, January 18, 2010 8:29:51 AM(UTC)
afresquez
My washing machine doesn't agitate on the wash cycle but it does work on the spin cycle. How do you fix this?
sidfink43
#2 Posted : Wednesday, January 20, 2010 6:25:29 AM(UTC)
sidfink43
Since your machine performs correctly in the rinse cycle, it does not seem like there is a mechanical problem. The problem is likely in your timer not sending the correct electrical current to the motor.
Take off the connection to the timer and clean it thoroughly with contact cleaner and reseat it. Also check all of the wiring between the motor and the timer. If everything checks out, try replacing the timer, this part here.
Part number: AP4024921
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Savings through Textbook Rentals (General Talk)
by Guest 6/25/2024 4:12:42 AM(UTC)
Digital transformation to move into the future (General Talk)
by Biyen 6/19/2024 12:57:45 PM(UTC)
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Kenmore Elite Commercial#25344723100 (Refrigerator & Freezer Repair)
by Stubblefield 6/13/2024 5:47:53 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Maximizing Savings through Textbook Rentals (General Talk)
by Guest 6/9/2024 10:31:43 PM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
KRMF706EBS01 Door Ajar Alarming (Refrigerator & Freezer Repair)
by Guest 5/24/2024 5:38:21 AM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Natural gas orifices GE range (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/12/2024 2:30:45 PM(UTC)
