Horacio
#1 Posted : 17 years ago
Horacio
Ge Dryer is noise. I already ordered the drum slides, belt and drum bearing kit. Any chance I can get step by step instructions on how to open and remove the drum? Thank you.
bambiblaster
#2 Posted : 17 years ago
bambiblaster
Here is some steps for the dryer for you..
http://www.applianceaid.com/ge-dryers.html
#3 Posted : 17 years ago
Open the door and remove the screws from inside of the door frame holding the top panel.
Lift the top panel and remove the screw on each side holding the front panel. Remove the wires from the door switch (mark them first) and remove the front panel.
Remove the access panel on the back of the dryer.
Remove the belt from the idler and the motor pulleys (draw a picture of the belt assembly first to know how to put it back).
Grab the drum with both hands and pull it forward.
Dryer Repair Again and Again (Dryer Repair)
by Guest 3 years ago
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 3 years ago
Dryer repairs (Dryer Repair)
by P3FE 3 years ago
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 5 years ago
Dryer Repair Issue (Dryer Repair)
by jdharrin 5 years ago
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 7 years ago
Dryer repair Help! (Dryer Repair)
by Hah45 7 years ago
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 9 years ago
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 9 years ago
Dryer Repair (Dryer Repair)
by sotomargie 9 years ago
Dryer repair (Dryer Repair)
by dchurch 9 years ago
by jaybick 10 years ago
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10 years ago
by Tom Campion 11 years ago
by kencorey281@gmail.com 11 years ago
