carloswifey
#1 Posted : Tuesday, March 25, 2008 1:02:15 PM(UTC)
carloswifey
While doing laundry last night, I found the washer off with the knob between rinse and spin, pulled out so it should have been on. I tried to start it again from there, but it did nothing. I unplugged it & tried it again, still nothing. Checked all the wiring and took all the clothes out. I managed to get it to fill with water again on the rinse cycle, but when it should have started spinning, it stopped, hummed for a minute, and died again. I cannot get it do anything but fill with water. Any suggestions?? Also, is there a way to get it to drain the water sitting in the basin? I emptied with a cup and a bucket earlier, but I really don't want to do that again if I don't have to. Thanks!
#2 Posted : Wednesday, March 26, 2008 11:50:10 AM(UTC)
Remove the cabinet, remove the pump and see if the washer will work. You have to bypass the lid switch to have it work on the spin cycle.
Post your findings, please.
Begochu
#3 Posted : Wednesday, January 4, 2012 8:08:36 AM(UTC)
Begochu
If you have a drain on the floor, you can lower the hose down into it.
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
Washer won't spin or drain (Washer Repair)
by MaHarvey 3/27/2013 10:32:50 AM(UTC)
Kenmore 90 Washer won't spin or drain (Washer Repair)
by Salish25 7/17/2012 10:12:03 PM(UTC)
Kenmore Elite Washer Won't Spin or Drain (Washer Repair)
by peetey 6/9/2012 3:07:57 PM(UTC)
by chas0073 5/8/2012 10:27:28 AM(UTC)
Roper washer won't spin or drain (Washer Repair)
by diy4now 1/22/2012 6:08:35 AM(UTC)
Estate washer won't spin or drain, agitate cycle grinds to halt (Washer Repair)
by brdnstn 9/20/2011 5:51:52 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
by Jamie Conyer 3/20/2011 9:30:38 AM(UTC)
Galaxy washer won't spin or drain (Washer Repair)
by peterg1 5/11/2010 3:48:34 PM(UTC)
by chefgarden 4/18/2010 11:25:40 AM(UTC)
Washer won't spin or drain = overflow (Washer Repair)
by claudema 11/17/2009 6:47:01 AM(UTC)
washer won't spin or drain water out (Washer Repair)
by christine53 11/11/2009 2:01:51 PM(UTC)
by bajaeddie 10/19/2009 7:33:52 AM(UTC)
by Jon B 10/9/2009 7:18:00 AM(UTC)
