bajaeddie
#1 Posted : Monday, October 19, 2009 7:33:52 AM(UTC)
bajaeddie
When I start the machine, it fills and agitates fine. When it finishes the wash (agitation) cycle, it stops when it should start the drain/spin cycle. The same thing occurs during the rinse cycle. If I advance the time it won't do anything but fill and agitate
Does this sound like a lid switch or a timer problem? :
Eddie
sidfink43
#2 Posted : Tuesday, October 20, 2009 1:40:25 PM(UTC)
sidfink43
Sounds like the lid switch, but it is easy to check out. Just by pass it and see if it spins, if it does replace the lid switch and you are all set.
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
Washer won't spin or drain (Washer Repair)
by MaHarvey 3/27/2013 10:32:50 AM(UTC)
Kenmore 90 Washer won't spin or drain (Washer Repair)
by Salish25 7/17/2012 10:12:03 PM(UTC)
Kenmore Elite Washer Won't Spin or Drain (Washer Repair)
by peetey 6/9/2012 3:07:57 PM(UTC)
by chas0073 5/8/2012 10:27:28 AM(UTC)
Roper washer won't spin or drain (Washer Repair)
by diy4now 1/22/2012 6:08:35 AM(UTC)
Estate washer won't spin or drain, agitate cycle grinds to halt (Washer Repair)
by brdnstn 9/20/2011 5:51:52 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
by Jamie Conyer 3/20/2011 9:30:38 AM(UTC)
Galaxy washer won't spin or drain (Washer Repair)
by peterg1 5/11/2010 3:48:34 PM(UTC)
by chefgarden 4/18/2010 11:25:40 AM(UTC)
Washer won't spin or drain = overflow (Washer Repair)
by claudema 11/17/2009 6:47:01 AM(UTC)
washer won't spin or drain water out (Washer Repair)
by christine53 11/11/2009 2:01:51 PM(UTC)
by Jon B 10/9/2009 7:18:00 AM(UTC)
GE washer won't spin or drain (Washer Repair)
by ngavrelos 8/23/2009 1:08:06 PM(UTC)
