I don't know how old this stacked unit is but it worked great UNTIL the washer wouldn't spin or drain. I don't know if its worth fixing, or what might be wrong. Can you help ??
The most common cause is a failed lid switch.
Originally Posted by: magician59  The most common cause is a failed lid switch. Thank you ! How do I access that switch ? Whirlpool Model LTE5243DQ3
