cathycole01
#1 Posted : Tuesday, January 5, 2010 1:02:46 PM(UTC)
cathycole01
I just received my part to replace the clock and controls on my oven (part # WB27T10409). I was able to unplug and re-plug all but 2 white wires with clear/white plastic ends at the bottom of the part. These 2 don't seem to want to come off. Is there a trick to it?
#2 Posted : Tuesday, January 5, 2010 5:56:46 PM(UTC)
Try to pull them out, carefully using a flat blade screwdriver.
cathycole01
#3 Posted : Tuesday, January 5, 2010 6:06:40 PM(UTC)
cathycole01
Do you mean like pry them from the bottom? I have tried that but was afraid of messing up the plastic ends. Maybe I need to try a little harder ?
#4 Posted : Tuesday, January 5, 2010 6:19:12 PM(UTC)
Do not worry too much about that plastic insulation and try it harder.
1967 GE wall oven clock noisy (Oven Repair (including Ranges and Cooktops))
by Madroadahead 10/21/2014 10:07:24 AM(UTC)
Whirlpool Accubake Oven Clock display issue (Oven Repair (including Ranges and Cooktops))
by jimkenzie 2/24/2014 7:48:06 PM(UTC)
Oven clock (Oven Repair (including Ranges and Cooktops))
by rspeer14 2/1/2014 8:02:35 AM(UTC)
Amana Electric Oven Clock Out, No Temp Control in Oven (Oven Repair (including Ranges and Cooktops))
by Phractal33 1/5/2014 6:10:04 AM(UTC)
Jenn-Air wall oven clock blinks (Oven Repair (including Ranges and Cooktops))
by papaaustin 1/30/2013 9:52:57 AM(UTC)
dacor oven clock (Oven Repair (including Ranges and Cooktops))
by jackson 15 7/14/2012 8:42:45 AM(UTC)
Tappan (Model # Missing) Dbl Oven Clock Prbm (Oven Repair (including Ranges and Cooktops))
by jerrypettit 5/29/2012 9:42:22 AM(UTC)
Oven clock is beeping, won't turn on - just used broiler (Oven Repair (including Ranges and Cooktops))
by Beth R. 5/25/2012 8:59:11 AM(UTC)
How to replace oven clock/timer? (Oven Repair (including Ranges and Cooktops))
by aec393 12/15/2011 11:46:50 AM(UTC)
Oven clock slowly fades and oven shuts off (Oven Repair (including Ranges and Cooktops))
by elroymcoy 7/20/2011 10:51:18 AM(UTC)
kenmore oven oven clock different (Oven Repair (including Ranges and Cooktops))
by doallservices1 12/26/2010 9:50:08 PM(UTC)
Oven Clock , Locked door display blinking but not locked (Oven Repair (including Ranges and Cooktops))
by RaviM 7/27/2009 4:04:06 PM(UTC)
Whirlpool oven clock not keeping time (Oven Repair (including Ranges and Cooktops))
by RondaR 6/22/2009 7:04:42 PM(UTC)
kenmore oven clock (Oven Repair (including Ranges and Cooktops))
by zanezanel 5/28/2009 6:12:54 AM(UTC)
Jenn Air electric oven clock repair (Oven Repair (including Ranges and Cooktops))
by tbdbitljim 2/24/2009 11:25:58 AM(UTC)
